How to Replace Center Aluminum Piece?
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
BeautifulBasics
Car: 2005 G35 Coupe
Hello,
I am looking for the aluminum dash cover piece that is circled with arrow in the picture below. Mine has dents/scratches and I would like to replace it if possible. I want to use only Infiniti parts, please.
Any advice is sincerely appreciated!
Dealer.
Or junkyard.
joker350gt
time to go DD and get the JDM kit man
BeautifulBasics
Car: 2005 G35 Coupe
Hello,
Thank you so much for your help!
Is the aluminum piece that I need to replace all by itself or is it attached to the radio/air conditioning? I didn't know if the aluminum piece covering was one entire piece; will I basically have to purchase an entire new radio/air conditioning or just the aluminum cover? I do want it stock in Infniti parts. Also, if I do find it for sale somewhere or at the junk yard, will it be hard to replace?
Thank you, sincerely, for your assistance!
BeautifulBasics
Car: 2005 G35 Coupe
Also, if I found an aluminum piece with navigation cheap within a junk yard would that work okay? Is the aluminum piece all one when it has navigation or is the aluminum covering over the navigation separate? I don't currently have navigation and wondered if this would be an issue when looking to replace this particular aluminum piece.
p.s. I apologize if I am asking excessive questions...I am a true girlie girl and don't know much about cars. Thanks for your patience!
CrackaLackin
Car: 2005 G35 Sedan 3.5L Lakeshore Slate/Um... the tan/grey one
Looking at some pictures of console with nav, i think the piece around the A/C radio controls is the same*, so that MIGHT be a usable replacement
As for whether that even feasible to swap, I can't speculate
* The piece that appears to be different to compensate for the nav screen is the piece that surrounds the highlighted aluminum piece in your picture
Return to “G35 and G37 Interior, Exterior and Audio”
