niswiz »
https://forums.nicoclub.com/niswiz-u107598.html
Mon May 04, 2009 1:07 pm
i did this up to yesterday.had to replace some parts in mine. the easiest way is to go from underneath the car so get a jack and some jack stands,jack up the car from the front beam infront the radiator.i used the jack stands under my crossmember.make sure when u r jacking the handbrake is down and not up so the car comes forward and the jack doesn't go forward.place something behind the rear wheels after the propping the car with the stands. next take off the battery leads or u'll be sorry. u'll need a 12mm and 14mm spanners. there is a black wire that jus unplugs, next the cable from the battery that's black with a red stripe is held on with a 12mm nut.this wire goes to the starter solenoid.after all that's removed then use the 14mm spanner to remove the 2 starter bolts.one should be in clear sight with the other one slightly above.after removing these bots the starter is loose.last but not least push the started to the front of the car between the intake manifold brace and once it's out of the grear box bell housing turn it downwards and take it out.good luck.it's quite simple.
