how to repalce/clean the battery cable
nhuanlieu
Hi, my 1994 Q45 the battery cable (red part http://cgi.ebay.com/ebaymotors..._1214 in this picture below) is acting up due to looseness and/or dirtiness, I have to clean it once it awhile or else the car won't start and will dies in the middle of driving afetr some bumpy ride.
I am tired of having to maintenance it and was wondering If I may replace it with a standard termina or just soak it in soda or gum cleanser?
BLACKonBLACK98
Car: Q45, LS400, STS-V
i clipped my oem connectors and ran them into a multigauge audio terminal.
nhuanlieu
Nice job. I will try to do a standard terminal with a similar clipping job. Hope to turns out as good job as yours/ Thanks.
oldmako
Car: '99 Infiniti Q45 190K Black&Tan
'96 Chevy Silverado 5.0 245K
'89 23' Irvette CC F351
Hard to believe that a car this electric came stock with such cheesy connectors. But I suppose they have to cut costs wherever possible.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
They do the job and have been doing it for 14+ years, Maybe with some cleaning and basic battery maintenance they would have lasted longer.
oldmako
......not another one...
Infinitiguy19
I will be the first to admit I am not crazy on maintenance, I may have a ton of knowledge about the Q45 (Or at least I feel I do). But if you keep things clean they will last longer right?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Corroded battery terminals are not a good thing. Cleaning them is about as high tech as brushing your teeth.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Baking soda and water are your friends when cleaning battery terminals. Applying dielectric grease to the terminals after everything's connected will help prevent more acid buildup.
My Maxima's positive battery terminal was very prone to acid buildup for some reason. Eventually it rotted back into the cable itself, out of sight. One day the car just wouldn't start. When I removed the cable clamp it fell completely apart due to the rot. Make sure if you're having intermittent starting issues that you're not looking at this happening to you down the road.
qship96
Car: 1996 Infiniti Q45
Battery cable clamps only build up crud IF the battery is defective and leaking acidic gas around its terminals{broken seal}......the entire problem STARTS with a bad battery, not clamps!!!!!!
unknown007
Car: White 1993 Q45 (G50)
BLACKonBLACK98 wrote:i clipped my oem connectors and ran them into a multigauge audio terminal.
where you run your amp wire?Like how inside the engine bay?I dont want it sitting on the tower.Nice job by the way I was thinking of doing the same when I saw those at Bestbuy.
BLACKonBLACK98
that's just regular power and ground... no amp wire ran yet.
Infinitiguy19
Looks like 2 powers and a ground.
Q451990
I have found those treated felt rings that fit over the battery terminal and under the clamp to be an excellent investment. They are available at parts stores by the batteries... amazingly cheap insurance at less than $1 a pair.
Heath
qship96
Get a dozen pairs and use them as stocking stuffers for all your buddies next Christmas!
Denver90Q
Car: 1990 Q45 145K miles beige, 1995 Q45t green 80K miles , 1998 Frontier 140K miles black
I think the dealer charged me $800 to replace the positive cable on my 1990 a couple of years ago. Probably more now.
Infinitiguy19
Wow no offense but you got taken for a very expensive ride.
