evildky »
https://forums.nicoclub.com/evildky-u13100.html
Sun Jun 20, 2010 7:29 pm
350 hp is certainly a lto to handle in these cars but not enough to warrant excessive reinforcement and added bracing, 350s also is within the ability of the stock R180 to handle, the r200 is a common upgrade and it's much easier to find a limited slip and cv axle upgrade is also a good idea when adding power
that being said, if you intend to to much racing wiht the car thats when the stiffening comes in handy, and there are a few diffeent schools fo thought, a weld in cage will go a long way to stiffening the chassis done right, beyond the cage
stitch welding can add a suprizing amount of rigidity to the chassis without changing or effecting the use of the car
pdk fabrication makes a strut tower bar that ties into the frame rail above the sway bar mount as well s the firewall
Bad dog makes beefier longer 2 piece frame rails that also serve as subframe connectors, your car beig a 260 I'm not sure if you'll need the over the stock rail type or the rail replacement type
sem people add box tubing to the inner rockers, somereplace the stock rails with full boxed steel and others make their own sub frame connectors
