How To: Removing s13 Chassis Harness?? (headlights, ect, ect)
daconkiftador
Car: '92 Coupe SE, '83 Rabbit GTi, '91 Golf GTi
I already pulled the harness going from my ECU to my injectors, ect ect all the way out, but Im struggling with trying to get the actual chassis harness out. I cant seem to get the pass side, infront of wheel well fuse/relay box unclipped from the wiring so I can pull it thru the firewall towards the interior. Is the harness suppose to pull thru the firewall towards the interior or is the interior harness suppose to pull thru towards the engine bay? If anyone could help me out, thanks!
sil8y-X
Car: 1989 Nissan 240sx Hatch
Yes, it will pull through the hole in the drivers side panel. In order to get the smaller relay box out all you need to do is pull the relay's out. The big one needs to be completely disassembled. Take your time and remove the electrical connectors from the metal bracket. Use a small screw driver and they will eventually come off. Once they are off you need to unbolt the metal bracket from the fuse box and take it out completely. Next you need to take the plastic cover on the bottom of the fuse/relay box off(6 clips hold it on). Take the fuse's and relay's out and presto, it fits through the hole.
