lmao +1Darius wrote:Dude, use a gear puller and a socket that fits through the middle of the crank pulley to get that thing off.
YOU HAVE TO REMOVE THE LOWER COVER TO GET AT YOUR TIMING BELT TENSIONER. DO NOT PRY!
Ok... not to sound mean or anything but are you sure you know what you are doing? This is a very serious job, especially since our motors have ZERO tolerance heads.. IE if you miss one tooth, and turn your motor over.... yup cylinder head into Valve...=****ed.......IowaRB240SX wrote:And I am not replacing the belt. It has a new one on it. I am swapping out cams and cam gears. That is kinda why I was trying not to dissasemble the bottom end of the belt setup.
Note: Depending on what gear puller you receive, you may want to place a washer between the pin on the gear puller and the hole on crank. (act as a buffer) I have a nice Proto gear puller and I did this because the tip of the puller was over 60 degrees and I did not want to damage the threads inside the crank.IowaRB240SX wrote:I already have the bolt out of the crank pully. So all I need is the puller, will stop tonight to borrow one for A.Z.
Thats why you just put the crank pulley bolt in the hole and let it rest there... works like a charm.l0nestar wrote:
Just a thought..
Just a thought..
I've been keeping most of the negative comments to myself lately. Darius, I could totally rip you apart on your build but you've had so many bad things happen to you, I decided to spare you.Darius wrote:WHAT?! And prying on the tensioner isn't dumber?
Dude you've gotta ease up a little. I think a lot of people, including myself, are getting tired of your negative posts lately.
