240_Keyy wrote:yeah, you are wrong, so here is your correction...
You have to completely remove the splash guard because the 300zx rotor tries to occupy the same space at the same time and physics has a bit of a problem with that...
That's good to know. I plan on doing the front Z32 upgrade once I get finished with my suspension work.AceInhole wrote:Complete removal is not necessary, but I'd recommend it, as when you cut it, you usually end up bending it... sometimes enough to have it scrape the rotor after a bit of heat is added from heavy braking (happened to my rears).
AceInhole wrote:the only place the z32 rotors interfere with are the edges of the sheild where they curl over the rotor. Cutting the outside edge of the sheild will work fine. Complete removal is not necessary, but I'd recommend it, as when you cut it, you usually end up bending it... sometimes enough to have it scrape the rotor after a bit of heat is added from heavy braking (happened to my rears).
kongmike wrote:OMG.... i m having 30mm rotors... i hope it wont holding my rotors.. if i need to remove it, anyone can me how to remove it in detail.esp what tools i need.. 240 is my only car.. i need to prepare everything, coz i dont have other car to get other things in case i m stuck...
C-Kwik wrote:Take off the hub, use a long flathead screwdriver and pry the sucker off. Not hard at all. Removing it may expose the rotor a little to getting wet, but it's fairly well protected by the wheels. The missing sheild will help get more air to the rotos though. Big plus in my book.
240_Keyy wrote:Uhhh, I am definitely going to have to disagree with you on this one. When I put on my Z rotors even with the outer lip cut off the whole inner face of the splash guard was touching my rotor. In fact you could not put on the rotor and spin it because the splash guard was holding it.
Then again, maybe it is because I have 30mm rotors?
