How to remove the shift knob
keggersr02
Car: 2007 Nissan Versa 1.8 S
could someone help me with this i left my dog in my car while i ran in the store and he decided to chew on my shift knob
MIdnkight-lude
i guess i am the only help. i am one of the only one that has change mine. if you want i will take a picture of it in the morning.
here are the following shift knob that will work.
Sparco Globe X. ( the one i am using)Sparco Fast X.Momo Race Evo w/ Reverse up.Razo GT advance (Very similar to stock, but it doesnt look as good.)
(i work for a performance shop, so i test fitted a lot of differnt knobs from, MOMO, Sparco, And Razo.)
Ok how to remove it. This was not an easy task, since your dog already chewed it up, grab a dremmal, and start cutting the knob off. THIS IS THE EASIEST WAY.
The only thing holding the knob onto the shift knob is a TIGHT FIT. if you are able to get something that will slowly pull the knob straight off the shift it will work. It is not screwed in, or glued in. The end of the shifter has those cut grip like a file on it. (I will try to take a pictures so you can see what i mean) and the plastic is basely tightly fitted round it.
You can also try taking the knob apart peice by peices. The top part where the 1-6 can come off. then you can remove the rubber/vynal cover off the plastic knob. Then the last part it to put up with all your might to remove it from the shifter.
if Someone else figure out a faster/easier way to keep the knob, please do tell, i just end up hacking my off with a cutting wheel.
Clipsed
Car: 07 ALL BLACK Nissan C11ST, 01 Mustang GT Vert, and 94 Suzuki Sidekick JX 4x4.
I looked in the service manual, and it did not say anything about actually removing it, but where I was told to go to remove it, this is what it said . . .
"SHIFT CONTROL PFP:32982Inspection UCS0065H Check contact surface and sliding surface of fork rod and shiftfork for wear, damage, and bend. Replace if necessary."
What does that have to do with removing it???
Sorry I could not be of help, but seems as though Lude has the best input thus far!!! lol
BenzTech Gone Versa
Car: 2007 Nissan Versa 1.8SL
I would leave your dog in the car for 10 more minutes....lol.yea it just pulls up....use all your stregnth!
MIdnkight-lude
proxim2020
Nice Job on the pics A picture's worth a thousand words.
MIdnkight-lude
one thing to note, i cut away the plastic around the boot, so that when i puill the revese up it doesnt catch on anything on the new shift knob. since i cant put a stock on back on, it makes it look cleaner IMHO.
keggersr02
Thanks for the info and pics i got it figured out i will try to post pictures later
MIdnkight-lude
bump bump since it hard for most of the ppl to find.
2dr_sentra
Car: 1997 200SX SE-R, 2007 Versa SL 6spd
Nice looks good.
ME18VERSA
Car: 09 nissan versa
89 5.0 mustang
if any of you have your oem black shift knob i would be interested in purchasing it please let me know shoot me a email [email protected]
