how to remove the ignition coil
jsolis12
Car: 95 240sx
i was trying to take out the ignition coil on my KA to test it to see if its good or not because my car has no spark!!
i was wondering the steps to take it off!!
slipknot555_666_69
Car: 97 nissan 240sx
hook a spark plug to the end of the wire going into the cap and see if it sparks if it does then its not your ignition coil
Seishuku
Car: 1987 Nissan S12, 5-speed, SR20DE+T 50trim T3@15PSI, Megasquirt 1 029y4
95... Internal coil?
Easiest would probably be to take a spare spark plug, and just pull off one of the plug wires and just set the spare plug somewhere it can be grounded and fire it up.
If it doesn't run at all, and you aren't getting any spark, then it's probably the coil, but if you're getting spark but still doesn't run, then it's obviously something else.
