ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.html
Thu Aug 25, 2011 6:26 am
The hold down cir-clip will need replacing if a hammer and screw driver are used to remove. If you want to re use use a cir clip, pliers are a must. Internal or external will both work but the operation is opposite with each.
That small piece of metal holds that wheel assembly together, so it must not be deformed.
