javelinmania »
https://forums.nicoclub.com/javelinmania-u302229.html
Mon Jul 26, 2021 6:47 am
I have a 2007 Quest that I bought at auction and it had a lot of error codes. Took off the intake manifold and replaced the plugs, coils, cam shaft sensors and other stuff. Then I went to replace the Heated O2 Sensors. Found the front one and replaced it. Couldn't find the second one. Then I discovered that the Cat had been taken off and a straight pipe put in its place. I've been trying to get the two bolts that go up into the exhaust manifold off. I have tried penetrating oil, I have tried Heat and I'm beginning to round the heads on the bolts. I'm starting to think I may have to remove the exhaust manifold which will probably have the same issues.
Suggestions? Tips?
If I have to pull the engine I might as well get a JDM engine.
