Empty V wrote:Great description fueler, I'm not sure if this is the same but for my 01 you have to open the glass in order to remove the plastic after the screws have been removed.
Thanks, you are absolutely correct spec v, i forgot about that Ill be taking that back panel out and always realize last minute that the window needs to be open You need to pop open the back window or the panel wont come off because of the window latch, you can save that step for last to make things easier
