How to remove seats?
BJS
Car: 07 Versa
How do you remove the front seats in the Versa? I can't seem to figure it out by looking at it.
kc5f
Car: 2008 Nissan Versa SL HB CVT (daughter)
2007's Nissan Versa (both RIP)
2012 Nissan Versa
2015 Nissan Versa Note
2016 Nissan Juke.
(From the service manual...)
Front Seat Removal and Installation
CAUTION: Disconnect both battery cables before work.
MANUAL SEATRemoval1. Remove the rear leg covers.2. Remove the front leg covers.3. Remove the mounting bolts on the back side of the front seat. (TORX bolt: T50)4. Remove the mounting bolts on the front side of the front seat. (TORX bolt: T50)5. Disconnect the harness connector under the seat and remove harness securing clips.CAUTION:Before removal, be sure to turn ignition switch OFF, disconnect both battery cables, and then wait for at least 3 minutes.6. Set seatback in a neutral position, and then remove front seat from the vehicle.
InstallationInstall in the reverse order of removal. Be careful of the following three points. Before the installation, confirm that the inside and outside slide rails are locked at the same positions. Confirm that the slide rail location pin is set to the hole on the floor. Clamp the harness in position.
BJS
Car: 07 Versa
Awsome thanks - this helped alot!
