How to remove "rust" from new brakes?
All things Altima Coupe.
cubaton3
Car: 2009 Nissan Altima Coupe
I just got new brakes about 2 months ago, they got rusted really quickly, I made some research and this seems to be normal, but is there a way I can get rid of it? Somebody told me to use WD-40 but I don't wanna apply anything to it... Here's a pic .. Only the back brakes
Whoever told you WD-40 needs to be drowned in a bucket of bleach.
What you'e seeing is pretty normal for cheap, un-coated rotors.
Pull off your wheels, and remove the rear rotors. Take some steel wool or sandpaper and clean up the rust. Wipe it down with soap and water, dry it quick. Now, see the shiny part? That's called the SWEPT AREA. That's where the pads grab the rotor to stop your car. Don't touch that area.
In fact, mask that area off with tape - front and rear of rotor. Now, get some GOOD spray paint (rustoleum is good) and paint the rotor (black is a good choice). Give it 2-3 thin coats, let it dry in the sun in between coats.
Unmask the swept area of the rotor. Your rotor should now look like this:
Reinstall. You can do the same to the fronts.
When you eventually buy new rotors, buy a zinc-coated rotor... they'll stay new-looking.
cubaton3
AZhitman wrote:Whoever told you WD-40 needs to be drowned in a bucket of bleach.
Wow man, thank you a lot, I will absolutely try that.
You bet homey - that's why we're here.
Stick around here, and you'll know more about cars than any of your friends in no time. :)
SanoSuKe
"bucket of bleach" hahaha
:chuckle:
