VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Sat Dec 05, 2020 4:48 am
I'd pull off the plastic door sills (they just pop off) and run your wires alongside the existing body harness. You can fish them past the b-pillar or take it loose, it also pops off (although if I recall, on a Path you need to remove the lower seat belt anchor, 14mm). The only place fishing is really necessary is around the rear wheel well toward the back of the car, because the rear panels are such a total PIA. If you need to fish a big bundle or thick wires, get a roll of hookup wire from the parts store and fish it through first as a "guide wire", then tie it around the big bundle and pull that through rather than pushing. Much easier that way.
