how to remove pins from ecu harness?
240dx
Car: '97 Nissan 240SX LE
Does anybody know how to remove the pins from the ecu harness in an s14?
I searched and couldnt find much information.
diggles240
Car: 1996 240sx SE
2005 Altima 2.5S
This is a focus on plugs but will give you some idea:
gumby74
I filed down a paper clip a little bit. The main ecu plug should be similar to the S13 in that it collapses. Once you have the plug "opened" it is very easy to slide the paperclip in and worm the locking tab down while gently pulling the wire out.
I hope some of that made sense.
