How to remove pin from ecu plug
dustyk
Im running an AEM EMS on my car and Ive already installed a couple extra plugs into the ecu plug to run the extra switched grounds etc. I have taken ecu plugs out of hondas before but Im not sure how to remove pins from the ecu plug on a nissan.
Anyone taken pins out or repined a nissan harness let me know how you removed the pins?
xero1
Car: 08 Altima Coupe
find a tool truck, and get an import connector pin removal kit. it come with 5 or 8 special pieces.
S14-NEO
Car: 1995 nissan 240sx RB25 NEO powered
dotn forget that there is locking clips that need to be removed. the clips are almost the length of the plug itself...they arent indiviually held in . once you remove the locks, you can remove the pins very easily with a small pic
