slownslurious »
https://forums.nicoclub.com/slownslurious-u29303.html
Sat Oct 28, 2006 11:01 am
use a wirebrush instead of sandpaper, its easier to get the rust out of the cracks, gaps, and curves. If the rust is left anywhere it will continue to rust. Its ok to use sandpaper on the long flat surfaces afterwards to try and get it to look smooth again, if after using the wirebrush to remove rust the surface is left pitted. Soak a rag in "prep all" or a similar grease remover, wipe down the area, then use a clean rag to wipe it again. I agree using brush on product is better for rust prevention, but you should use a rust remover (most come in jelly form) first to remove the large patches of rust. Like I said, any rust left will continue to rust. After this your product may require you to wirebrush again to get the rust that has been removed off. If so, use prep all again and wipe down the surface. If not, allow it to dry according to package instructions before continuing. Next I use a brush on rust convertor (be sure to stir it until its creamy and has no liquid on top or it will not apply correctly). Once this dries, then you should use a top coat. Rustoleum brand paint is pretty good stuff. If you apply it correctly it will 'self level' and you won't be able to see the brush strokes. If you dont care how it looks then spray on underbody coating is a good rust preventative as well. smells bad though.
