how to remove or where to get it from?
Acumo
Car: 92 hatch
help on how to remove or a sticky plz thx
Hijacker
Car: '92 240sx Convertible
'94 F-150
That's the thermostat housing. Why are you removing it? In any case, it's held in with 2 10mm or 12mm headed bolts (can't remember which off the top of my head)
Acumo
Car: 92 hatch
i have to change it because one of the bolts that hold the hose coming from the rad snapped and its like inside im scared to drill it in so i was going to get a new one but i dont know what i should do if u look close u can see the one to the right and if i get a new one do u know the part # or the car? thanks
idahotuner
Car: 2012 Dodge Ram 2500 6.7 Cummins
93 Nissan Sileighty
93 Honda Civic hatch
2011 Polaris Ranger
dude drilling and extrating is easy. we had about 4 bolts on my moter we had to do that to.
Hijacker
'94 F-150
I think that the housing is a RWD only component. The part number I pulled up is 11061-52F05, but I couldn't find it with a quick parts search on Midway or Courtesy.
Personally, I would try to use a bolt out or drill to get the old bolt out. Heck, if there's enough stickig out that you could get a good set of vice grips on, you can get it out.
However, to get to the two bolts holding the housing in, I'm 99% certain you'll need to remove the intake mani. The throttle body looks to be in the way too much.
Acumo
Car: 92 hatch
ok thanks alot im going to try and drill it because i cant get no grip to get it out with vicegrips so ill try nd drill it ok thanks
