180weaver »
https://forums.nicoclub.com/180weaver-u54414.html
Sat Oct 06, 2007 9:10 pm
if you are going to be doing this kind of work the chiltons manual is a must buy for like 20 bucks, also this site has a fsm(factory service manual that you can download) I looked at my chiltons and the lifters are completely different than my e so it seems like you are going to need a spring compressor and its called a valve cotter or snap ring. looks like the if the valve spring is still retained all you need to do is put the snap ring in place and place the lifter over it then shim to the correct clearance stem to guide on intake is .0008-.0021 and exhaust .0016-.0029 and the tightening procedure for the camshaft brackets are front 1 5 9 11 7 3 2 6 10 12 8 4it doesn't list a torque spec, but states to tighten in two or three steps in sequence. Hope this helps
Modified by 180weaver at 12:23 AM 10/7/2007
Modified by 180weaver at 12:33 AM 10/7/2007
Modified by 180weaver at 1:07 AM 10/7/2007
