how to remove & install starter motor?????
Redzunz
Car: '90 300ZX TT
can someone give me a guide on how to do it. thanks
CrazedZ32Owner
Car: 91 Z32 TT(no motor), 2008 350Z Nismo, 05 Pontiac Sunfire speed machine!!! :)
after you jack the car up and get it properly supported crawl underneath it. the starer is on the pass side of the transmission its either held on by 2 or 3 bolts but is pretty easy to get to. Just MAKE SURE you disconnect the battery cables before getting under there and handling the starter, if you ground yourself out on that bad boy you might not have any hair left. Not quite sure if you have to worry about the starter lining up 100% with the flywheel someone else can clarify if need be.... but yeah thats it repeat to install new starter
Redzunz
Car: '90 300ZX TT
thanks!!!, appreciate it
