how to remove & install rear brake pads????
Redzunz
Car: '90 300ZX TT
can someone give me an instruction on how to do all the above.
thanks
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
unbolt the calliper, remove pads? it's pretty self explanitory
CrazedZ32Owner
Car: 91 Z32 TT(no motor), 2008 350Z Nismo, 05 Pontiac Sunfire speed machine!!! :)
so much easier on newer cars that only have a piston on one side...
itsa300zx
Car: 1990 300zx NA W/TT swap
2011 Nissan Rogue S
2008 Highlander SR5
Brake pads are one of the easy things to do on these cars:
Once the wheel is off.
1) Pull off the wire clips off the pad retaining pins
2) remove the pad retaining pins by pulling them out. Then remove the spring clip
3) pull out the old pads
4) un cap the BMC (this make it easier to push the pistons back in)
5) use pry bar or suitable tool to push both pistons back into the caliper( I used the old pads as spacers)
6) install in reverse order
If you are doing the hand brakes/Shoes, thats another issue.
Redzunz
Car: '90 300ZX TT
Thanks
NissanFairladyZ32
Car: 91, Twin Turbo, 99 Miata 1.8L
itsa300zx wrote:Brake pads are one of the easy things to do on these cars:
