How to remove fuel rail assembly?
240novice
I have a '91 hatchback and try to replace the valve cover gasket. After unbolting valve cover, I realized that the cover won't go out because of the fuel rail assembly. How can I remove this? How many bolts do I have to remove for the removal? Thanks.
TheOne
Car: 93 240sx FB
you just need to remove the bolt that goes from the fuel rail to the valve cover and 2 bolts on the other side of the fuel rail(intake side), which are attached to a hanger thing, then you could just move the fuel rail enough to take out the valve cover.
