how to remove drivers side interior door panel
gildebrand
hi all, i need to get to the window motor for my 2000 xterra. anyone have step by step instructions, any illustrations would be great, especially since i have never seen the windor motor, also i need to manually roll up the window once i find the motor. again, thanks for any help and pics would be great too.
thank you.
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
Go to your parts store and get the door panel removal tool.
Panel removal is pretty easy. You have a couple screws in the handle on the arm rest, and I think another by the door handle itself.
Next, use the panel tool and slide it between the door panel and the door. There's plastic snap clips holding it on most of the way around.
ONce you have all those popped loose, lift the upper lip of the panel out of the window track and then disconnect the wiring harnesses from under the arm rest.
Big-Bird
Car: 2000 Xterra on 'Roids & 2004 Quest SL
check the email address you gave us for your NICO profile. I have sent you the PDF file on the complete interior removal for the 2000 Xterra
Good luck
XterraVersa
Car: 2002 Nissan Xterra
Nissan 350Z Nismo
This is from another site.:
soccerbrace; wrote:Just so you know, all you need is a couple of Phillips screwdrivers and a small flathead
Alright, so here is the panel you will be removing...
First, get at the 2 exposed screws
The first one is at the door handle bezel
You remove that with a Phillips head screw driver
Remove the little trim that is around the bezel. Be careful when doing this. First pull up on the ring, out on the back, and then forward.
do you see those two little tabs on the bezel? Those line up with the holes in the ring. there is also one that is forward too that you can see if you look closely
For the second exposed screw, you have to go into that little "cup" that you grab onto when closing the door.
Next, you remove that little arm rest type thingy
Arm rest thingy removed-another screw exposed
Remove this with a Phillips head screwdriver
now get that piece of trim with the controls off
You will see two electrical plugs. Remove them both, you might need the flat head for this. The one nearest is for the windows,
and the other is for the mirrors
One that is removed, the fourth and last screw is exposed (on the right)
By now, you should have all of these parts removed
Now take these two plugs
And stuff them through this hole
Now you can actually start removing the panel.
Start at the bottom and move the with of the door
up the sides
Finally it will be hanging off of the window sill. When it is at this point, tilt at an angle ad pull up. Directly up.
the naked door
Front of door panel
Back of door panel
a quick reminder, when you put it all back together, reverse the steps. When you are putting the ring back on the bezel, know that there is a front and back. the picture below shows you that the hole closest to you goes on the front little clip on the bezel
