+1 NicoClub is your friend.bakerboard wrote:yea if you run into a problem just shoot us a message here.
Thanks faja! finally got a chance to do this, i just got done removing the bumper, also replaced my headlights in the process AND fixed the sag. Your instructions were perfect, thanks again! when i get the chance i'll post pics for anyone else having the sagging problem in their front bumper... it was easy to fixFaja wrote:I have an 09 so I hope it's the same. To remove the bumper, you have to remove the plastic shield at the bottom of the engine, it's just held on mostly by plastic clips and 3 screws on each side. The clips are removed by pushing straight outward on the pinhead with a flat screwdriver and once you see the small opening just pull them out with your hand. You will also have to loosen the fender protectors which is the same process (those are just held in with the screwclips), you don't have to take out the whole thing, just loosen the front half (closest to the bumper) - removing the wheels will make this easier but not absolutely necessary. At the every edge (end) on both sides of the bumper, there is a screw that holds the bumper to the fender - those screws are just underneath the plastic shield around the tire area. Once you get those screws out, just pull out the bumper gently starting from one side to the front and then the other side to the front also. 2 People will make the job a little easier to pull out the bumper.
