Yup! This is exactly what I needed. Yes, I'm sure I did that before when I replaced shifter indicator trim, but I just couldn't do it this time. I'll try it again tonight. Thanks!!GoinTopless240 wrote:you have to undo the plastic clip from the shifter assembly (squeeze tabs and pull type). The wires are attached to the switches...
It's connected. Yes, I know what you mean. There's this click sound that releases the key, and somehow I don't hear it anymore.Eikon wrote:Do you have your battery disconnected? If so, reconnect so that you get power.
You can't remove the key w/out power for some reason.
