how to remove and replace m.brake cylinder
hek1620
Car: '89 240sx
mine is leaking badly, so i have to replace. how do i do this? thanks in advance.
240SX_89
Car: 1989 Nissan 240SX Fastback
RemovalDisconnect electrical wiring at cylinder reservoir. Disconnect and plug hydraulic lines at master cylinder. Drain fluid from reservoir. Remove cylinder mounting nuts and master cylinder.InstallationTo install master cylinder, reverse removal procedure. Bleed hydraulic system and check pedal height.
hek1620
Car: '89 240sx
thanks.
