how to remove all the window washer stuff?
EstoMax
Car: 95 240SX KA-t
94 d21 xe 4x4
hey guys
im thinkin about ripping my window washer tank/motor and everything out since i never use it anyway and it doesnt work lol
so im wondering if anyone has done that i kno where the washer fluid tank is but where is the motor and all the lines? i see the line going into the fender area from the end of the engine bay but i didnt follow it any further
thanks for any tips : )
max
eddiec
Car: 91 S13
you'll have to remve the fender liner to get at it better. the liner is held on by a few screws and some push-button fastners. to drain it just pull the hoses off. i think all the motors are inside the tank. so you can pull everything at once.
2Fass240us
Car: 93 240SX SE w/redtop
Eddie's right...the easiest way to get to it is to pull the passenger wheelwell liner. But the motors are on the outside of the tank. Mine had one for the front window and another for the rear.
Are you going to remove the turbing, too? Because you pretty much have to have the interior panels out to do this.
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
the tubing that goes to the hood nossles just runs up the top of the fender and into the engine bay. If you have the fender liner out its a peice of cake to remove.
eddiec
Car: 91 S13
if you have the rear sqirter its a little more work to get the tubing out. although i guess tou could leave it in there. i was going to reuse my rear quirter to spray the radiator with. kinda like those i/c sprayer thingys.
deathkeeper
I removed mine because it also did not work, and killed the fuse to my wipers if I hit the button (very bad!). The tank that holds the wiper fluid has the motors attached to it. I just removed the tank, cut the harness connecters off of the harness (they broke into pieces when I tried to remove them), taped off the ends, and zip-tied them to a suitable location. The hoses then can be easily followed and removed.
EstoMax
Car: 95 240SX KA-t
94 d21 xe 4x4
alright i got it removed
i got the tank out easy, just unhood the harness and i guess i could plug another pump for IC spray or whatever in the future..
the lines i got off too, had to loosen up the fender liner above the tire a bit
no rear lines for us coupies :P
tnx for the help
max
