This is great, thanks for info. I have some questions though, if i may:-RED_DET wrote:First you need to remove the radio trim piece. Then you need to remove the glove compartment. Then the trim piece and gauge cluster need to come out. You will have to unhook the transmission cable from the transmission so it will allow you to pull the cluster out far enough to unhook the cable from the back along with the lights/switches. Then remove the panel underneath the steering wheel. Now that you have done all of the above, there is a 12mm nut at each end of the dash located very close to the door jam. There are also screws behind the gauge cluster and also behind the middle vent section. Now on top of the dash on each end, there are two tabs that need to be removed very close to the windshield. THen remove the 10/12mm nuts. At this point you should be ready to pull the dash out. It easier to take the dash out the passenger side because the steering wheel won't allow you to take it out of the driver side.
Recap, remove all screws you see holding either trim pieces on or the gauge cluster. THere are only 4 nuts that have to be removed.
These codes refer to the body shapes over the yearsBuzzman wrote:Quick question. Being new to this forum, what is a B13 and B15?
