ThisIsSparTTa »
https://forums.nicoclub.com/thisisspartta-u210180.html
Tue Sep 09, 2014 9:30 am
Are you trying to replace the idler pulley stud or trying to remove the lower intake plenum? If just trying to replace the stud, you don't need to remove the lower plenum. It's part of the 120k procedure, and you'd back it out however you back out studs that have been sealed in with thread lock.
If removing the lower plenum, once you have the fuel rail and everything off there's several bolts to the heads. Once those are removed it should come right up, and I wouldn't think you'd need to take the backing plate off to let it slide out.
