How to reduce High HC reading from Smog Check
94 Q45
Hi, I bought a 94 Q45 and recently I got a reading from smog check and the HC level was near the maximum level. I want to know how can I reduce the HC level, also the car's MPG was not great, so I think the high HC is the cause, or maybe fuel injector is leaking or the fuel pressure regulator or fuel filter is bad. I have changed the air filter, spark plugs and clean the MAF sensor recently. Thank you for your thought.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
O2 sensors? Intake path?
