I recently acquired a 2004 G35X with the 6 cyl engine. The dipstick confounds me.... since it goes in at an angle.. apparently oil residue is on the side of the tube so when I pull out the dipstick to check the oil level, there is no clear point there the oil ends. there is residue well above the H mark and I know it's not overfull. If anyone could shed some light on how to read the dipstick when the oil is relatively clean I'd really appreciate it. i don't want to add oil when it doesn't need it and I want to make sure I do add it when it needs it.
I won't bother commenting on how difficult it is to even see where to put it since it's buried down out of the light.... and how contorted it is... whatever happened to straight down dipsticks that were easy to use?????
