Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Wed Apr 29, 2009 4:26 am
If you want just the low beams, put in a switch somewhere that will handle the current needed for the lights. Then all you need is a switch that will supply power to the low beam circuit for the lights. The Green/Yellow and Green/Blue circuits are the low beam circuits on their respective bulbs. Nissan gives dedicated power sources to each light, I'm not sure if you care enough to do that, but it wouldn't hurt.
If you need them to pop up as well, you can put in a seperate switch to raise them. The purple and the brown wires are the dedicated circuit in the factory setup. Purple supplies the switch, and brown goes to the motors.
