C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Mon Aug 25, 2003 9:27 am
No. Different types of suspensions respond differently. For example, a double-wishbone/multilink set-up will increase negative camber during compression which will positively react to body roll and provide a flatter contact patch with little to no static camber. A strut set-up has very little camber change during suspension movements. This means while the car is leaning, the tire will actually start to lean out(positive camber) in relation to the road surface. To get a flatter contact patch, more static camber will need to be dialed in. At the same time, if you have stiffer roll resistance in a strut suspension, it will stay flatter overall. This is the better compromise for a track car since less static negative camber will keep a flatter contact patch during braking(front). High caster angles for front strut suspensions can help to offset some of the lack of negative camber as it will allow the front wheels to gain negative camber while the wheel is being turned(outside wheel).
All this being said, if different parts are on the two cars, it may not work as well with the same settings on both cars.
