How To: RB25 trans mated to z32 Trans - LOTS of pictures
Booztd 3
Car: 1990 Nissan 300ZX TT
Guys
First off, I would like to preface this with a warning. THIS IS NOT FOR THE AVERAGE MECHANIC. Hell I wouldnt even recommend this for the skilled mechanic. I consulted my older brother who owns a speed shop in springfield IL named FC Customs (www.fccustoms.com) to help with the work. This work is being done because I am swapping an RB26DETT into my Z32. More info can be found at my website http://www.rbz32.com
Over the last two nights we broke down the Z32 transmission, as well as the RB25 RWD transmission. We then mated them together following Charlie C's suggestion that the input shaft needed to be swapped to compensate for bell housing lenght.
I will also re-preface this write-up by warning you almost every picture contains the 'shocker' LOL. We were feeling goofy during the process, so why not spice up the pics a little bit?
Here we have the Z32 Trans
You will begin by pulling the outter detent ball out of the trans. On the upper side close to where my bro's index finger is pointed in the picture above. Remove the 17mm bolt on the left hand side and remove the spring and then remove the ball. Keep these in a safe place.
Now you'll remove the front cover like so
Front Cover removed
Now you'll need a few different sets of snap-ring pliars. There is one small snap-ring and washer and a large snap-ring once you get the front cover off
Snap Rings
Now We'll work on the shifter rod. Begin by pulling the 10mm bolts out and pull the cover off. You'll see this
There are two dowel pins you need to remove in order to get the shifter rod out.
Now we'll remove the bell housing by removing the casing bolts in the middle of the trans. You'll need a hammer to separate the two pieces.
A close-up of the gear-set
Our next part is a highly debated topic regarding Z32 and RB trannies. The 4th gear synchros DONT grind, its actually the insert springs. You can see in the next few pics how the teeth have been ground and dulled down
Now you'll remove the forks from the gear-set
After you've removed the shifter rod and the pieces inside the trans, you can now remove the tail section casing
Here is another component that causes the grinding
Notice the teeth are worn down
Now this is where things get hairy. You're going to need the bomb-diggity puller set in order to get everything off the right way. We accomplished this witha $2500 Set from Snap-On
Gears starting to come off
Using the pinch puller for the lower bearing
We had to craft this next setup out of threaded rod and one of the pullers. It worked at least!
After removing the other gear above with the pullers, the remaining gears should come off with some prying/tapping of a hammer. Now the directions call for pressing the shafts out of the center-section. We did this using a press. Since the shafts are still bound together by the gears, you must press the shafts out one bit at a time, and then switch to the other shaft and press it out a bit. This makes is so the shafts dont bind.
This is how we felt at the end of night 1
Moving on to day two, we have an RB25 RWD Trans
I'm not going to go through the dissasembly process, because its quite identical to the process of removing the front/rear casings.
Here we have the Z32 Input/Output Shaft on the top, and the RB25 Input/Output Shaft on the bottom
Here are some comparison pictures of the bell housings
My stuff was pretty dirty and my bro's shop just had gotten a new parts washer in. This thing RULES. I give you ......"The Cuda"
Parts going in
Here's how the bell housing turned out
Center Section
Here the RB25 trans gearset.
Since I wont be needing alot of extra parts, we opted to cut the countershaft out with a plasma cutter, and avoid a crap-ton of parts removal.
Now since the input shaft isnt bound by the counter shaft, it slides right out
The mess we made
Now we're finally on to the reassembly process. We heated the parts on that usually get pressed on. We just put them in the parts washer for a few minutes and they went on pretty easy with a hammer. We used alot of the insert springs and such from the RB25 trans since they were in alot better shape than my Z32 trans. It basically ended up taking all the good parts from both and combining them.
Everything into place, forks are back on
Snap-Rings going back on
Front Cover sealed up
My brother on the right and tony (stallone) on the left. These guys were a huge help and I couldnt have done it withouth them
The completed RB25/Z32 Trans
Now onto some notes:
When I first read what needed to be done to the RB25 and Z32 trans it made a lot of sense, having to use a different input shaft to compensate for bell housing length, but the way I understood it was that the RB25 bell housing was longer, thus making the input shaft longer as well. If you read through this how-to, you’l definitely see that the bell housing is actually shorter. So in theory if we just switched the bell housings, the input shaft would be too long on the transmission, but this really isn’t the case. We measured the input shaft length, and theres only 1/8” different between input shafts. It is more than likely this 1/8” would be negligible when installing the transmission, considering the input shaft does not even fully seat on the pilot bushing. Even if you did run into that issue, you should be able to cut off the excess 1/8” from the Z32 input shaft.
Here is also a picture of the puller kit we used
Some pics of the shop and the cars
Panoz GTS on the dyno and STS C5
My bro's mid 10-sec stock block/stock head/stock cam 05 mustang
Their Ford GT
Blower & AFR Head setup going on an escalade
Arial View
Peace!
xsublimefrekx
Car: 1991 s13. SR20det, 1998 s14
amazing write up and amazing shop.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
um.....why? it just seems like a lot of work for what? different gearing? am I missing something? nice job with the writeup I just can't figure out why?
Booztd 3
evildky wrote:um.....why? it just seems like a lot of work for what? different gearing? am I missing something? nice job with the writeup I just can't figure out why?
Maybe you should have read the first few opening paragraphs.....
Booztd 3 wrote:This work is being done because I am swapping an RB26DETT into my Z32. More info can be found at my website http://www.rbz32.com
evildky
06 Nissan 350Z GT
ok I still don't get it, if you're putting an rb in why not just use the RB25 trans like everyone else? what about the Z32 internals made you want to run them over the Rb25 gearset? was the purpose to allow you to use the Z32's shorter tailhousings and linked shifter? I perspnally would love to hase a trans taht the shifter fitted directly into, did you do it to be able to use the stock trans mount? seems fabbing up new mounts would have been easier, again maybe I'm missing siomething, I just don't see why?
Booztd 3
evildky wrote:ok I still don't get it, if you're putting an rb in why not just use the RB25 trans like everyone else? what about the Z32 internals made you want to run them over the Rb25 gearset? was the purpose to allow you to use the Z32's shorter tailhousings and linked shifter? I perspnally would love to hase a trans taht the shifter fitted directly into, did you do it to be able to use the stock trans mount? seems fabbing up new mounts would have been easier, again maybe I'm missing siomething, I just don't see why?
Everyone else? There are only a handful of RB Z32's in existance, and I know they arent using the complete RB25 trans. The z32 internals are identical to the rb internals. My z32 had a 4th gear grind so I used the teardown as an opportunity to take all teh good parts from both trannies and make one solid transmission.
What I did allows me to use the stock trans mount, stock driveshaft, stock shifter, stock wiring harness, etc.....Two short evenings worth of work and I can do all of that AND have a rebuild transmission thatll shift like butter, is worth alot more than just throwing in an RB25 trans of which I have no history on, fabbing up a custom cross member, fabbing up the shifter area, and having a custom driveshaft made.......you dont agree?
evildky
06 Nissan 350Z GT
when I say everyone else I guell I mean all the S13, S14, Z31, S30 and S130's running RB's of which there are a lot! the Z32 swap is rare I suppose as it's a latteral move
as for the tradeoff of work, I am gonna guell the output shaft is splined the same so the slip yoke and shaft fromt he z32 can be retained just needs to be shortened, shorten and ballance at a professional shop is only aobur $100 with a 1 day turn around, and the shifter looks like it should come up in the right location and would allow for removal of all the extra linkage and brackets that burden the z32 trans, and I'd be suprised if it didn't fit the stock z32 crossmsmber but even if ti didn't it should eb a simple job to cut, pivot, slide or whatever is needed and weld it back together, and the beauty of the stock rb trans is if you should granade it you just swap another in it's place instead of repeating the mod process, not trying to bust your balls just trying to figure out where you're coming from, you obviously have some skills and lots of great tools and high dollar toys to play with (I have a thing for the Panoz Esperante which si of course the road going sibling of the GTS)
I did a similar swap in my 240Z, using a 240SX 5 speed, it only required changing the front case, mainshaft bearing and boring the countershaft holes, and then I had to have a driveshaft made as well as customizing the trans crossmsmber (and series 1 crossmsmbers are getting impossible to find) I did it all so I could have a 5th gear in a trans that could take a beating (I later swapped in a T-5 which worked with the same modified crossmsmber but required a completely custom drive shaft)
nice job
Booztd 3
evildky wrote: the beauty of the stock rb trans is if you should granade it you just swap another in it's place instead of repeating the mod process,
My argument to this....do you know what RB25 trannies are selling for right now? I'd rather spend 250 on a Z32 trannie and a night or two in the garage swapping the bunk parts than trying to track down an RB transmission and paying 800-900 for it
jEzTeR
Car: '07 Infiniti FX35
'02 Nissan Altima SE 3.5
'93 Nissan 240SX Hatch
Wow that is a great shop!
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Thanks for rthe write up and documentation.
As for the title of this forum, I seem to recall the 1600/2000 roadster was named the Fairlady in Japan.
evildky
06 Nissan 350Z GT
the raodsters were called fairlady's in usa as well, the Z was never a fairlady in america, excepting the fairlady edition in 96, of 300 cars
the z was to be a replacement for the 4 cylinder convertable and to carry on the fairlady name but MR K. changed the badges as he felt the name was too feminine for the us market and the 240z was born
and the fairlady was origionally given it's name due to the japanese CEO's fondness for the american movie "My Fairlady"
walperstyle
Car: s13 crap
ADMIN: Please do whatever you can to get these pictures back and hosted on the site server. This information is going to be a goldmine once the automatic R34's are selling in the US. Proper site maintenance requires admin to delete nonsense posts and questions with no answers so they don't show up, and indexing pictures of valuable information so it's not lost, as seen above.
Please PLEASE get in contact with this guy and see about finding the pictures.
