How to raise s14 safely?
S14Kouki10
Car: 1997 240sx
Well im in the process of adding subframe collars. I tried raising it from the frame rails but they just get all bend up. Any other good spot to jack it up from that wont cause damage? And where should i place the jack stands? thanks.
bersh240
jack from the diff.
jackstands go at the pinch welds.
many people use the frame rails/boobie lookin things/or subfame.
but the oe locations are the pinch welds..
DanThaMan
Car: 1993 240sx
dont put the jack stands at the pinchwelds!!!!! It will crush them, they are made for the stock scissor jack which has a slotted seat. I always use the boobie lookin things, they work great
S14Kouki10
Car: 1997 240sx
boobie looking thing??
krash
I use the pinch welds for everything..... nothing happens......
Use the diff and the front crossmember.
DamonDread
Car: 1987 Toyota Supra Turbo
krash wrote:I use the pinch welds for everything..... nothing happens......
:werd:
My s*** looks all tore up underneath cuz PO didnt know where to put em either. So he freegin decided on trial and error.
bersh240
DanThaMan wrote:dont put the jack stands at the pinchwelds!!!!! It will crush them, they are made for the stock scissor jack which has a slotted seat. I always use the boobie lookin things, they work great
if you would use jackstands with the lil slot in them you wouldnt have this problem...
http://www.harborfreight.com/automotive ... 38846.html
see? lil slot... the rubber pads make it even better.
dont say a method is wrong if you dont have the proper tools.
AZ89two4Tsx
When I had my s13, I used the frame rails the first time. HORRIBLE idea as I crushed the rear ones. Gave more ground clearance though....lol.
I've also used the pinch welds before. As stated above, they'll bend flat. Not a real big deal. Much better than using the frame rails. After that first time though, I would always try to use the front crossmember (by the radiator) or the diff.
Remember to use jackstands!
S14Kouki10
Car: 1997 240sx
Yea, will never again lift from frame rails. I bended up only a little. Stopped after seeing get crushed.
krash
seriously? All you need to do is use a wood block if you don't have a slotted jack. Come on now.
S14Kouki10
Car: 1997 240sx
I did it with a 2x4 after, i also made a groove right in the middle so it sat leveled with the frame rail.
DanThaMan
Car: 1993 240sx
I meant to write "Don't jack it from the pinch welds" My bad, just a simple proofreading error.
