How to raise rear of hood?
Type X(J)
Car: '98 240SX SE
I did a search on this but nothing came up, so I just wanted to ask you guys/gals, if you've done this, how would I raise the rear of my hood. I was thinking of using thick washers to lift up the mounting points. any ideas?
*oh wait - nvrmind I found a post - thx anyways
this thread can be deleted
GEO
Car: 95 240sx KA-T
No clue.. SPACERS?
[Zero-S]
Car: Tell me whats wrong with this picture. 3 240's, only one runs.
Its done with washers.
marshun
i used oversized nuts.
Dattebayo
i got some over sized nuts right here you can use...
:D
[Zero-S]
I knew someone was going to say it.
912.0turbo
2BN_S13 wrote:i got some over sized nuts right here you can use...
:D
:rotflmao
EnzoRWD
Car: 1997 Volvo 850 T5
make sure, if you're raising it any significant height, to also use LONGER BOLTS!!! im in the process of doing this, just thought i'd add that-Enzo
PantherRacer
Car: 1992 Nissan Skyline R32 RB20DET Sedan
LOL...I keep seeing this red 240 everyday...the rear hatch is off and to the side and so is the hood, it's under a garage type thingy...do you all think I could buy it and fix any probs or would it cost a lot? I don't know much bout restoring cars that seem to be in that condition
rousie13
Car: 2006 Nissan 350z Track Edition, 1997 Ford F250 4X4
Ok, now what exactly does this do?
MainEvent212
Car: 95 Nissan 240SX SE w/ SR20DET+goodies
old school cowl vent for cooling :pface
Type X(J)
Car: '98 240SX SE
thx for your input EnzoRWD
rousie13
MainEvent212 wrote:old school cowl vent for cooling :pface
Got ya. My sprung hinges do it for me. :ylsuper I have new ones, just too lazy to put em in.
jamie
I found that an easy way to lift the back of the hood a little is to spin on an on-ramp in the rain and nose into the wall...:-P
rousie13
^that will definately do the trick, but might cut down on the aerodynamics of the car
jamie
wasn't so bad, just shifted things around a little
Spazum888
i know this is an dead subject... but im tring the hood thing with washers... i also tried searching.... i got the washers on... new bolts on... good stuff. but the hood wont raise all the way with out scrashing the top part of the quarterpanell.... my question is your you place the washers where the hinge meets the hood or where the hinge meets the body?
is this right or am i doing totally backward?
i2ice4m3
Car: COUNTERSTRIKE!
i hope you have more washers on the rear bolts than the front ones-i'd count them but ehh...cant see em all :P
Spazum888
i started out with 12 on all 4 bolts... then i moved down to 10.... do i need to add one in the back?
ricebike
2002 Quest
2005 Altima
lol, that's mad high... i too try to search for that other member who posted what hardware he used to the 'T', but to no avail...
from what i've recalled, he put some plastic bag over it to show how it does force cooler air thru the engine bay... as well as using a thermometer to put up some actual numbers...
dam, my searching skills suck.
Spazum888
no seriously i have searched too, to avoid the flaming from people... cuz i know this is a pretty simple mod (havent been flamed yet and dont want to) but the only thing i have come out of searching was 1) longer bolts 2) washers... thats it... i was talking to a friend with an s13 who has done it and he said to "bow" the hood... have people push from the sides, and bend the hood....... he said it worked for him... i really dont feel like bending my hood just yet...
right now the hood shuts perfect, its a nice fit... just i cant pop the hood open all the way... we went out sliding tonight and no spike in the temp... worked pretty well for the first test run... now their is some place for the air to go through...
EnzoRWD
umm looking at that pic, you might want to check something. on the side of the hinge that mount to the car, there is a hook like catch that slots into part of the hood. its purpose is to prevent the hood from decapitating ppl in a crash. if u raise it too much, it wont catch. something to think about.however, since its built onto the hinge, putting spacer between the other side of the hinge and the car itself, rather than next to the hood, might be a better idea.-Enzo
90s13ka24e
this is a dead topic but ive found that puttin washer inbetween the hing and the car work alot better, plus they are alot eaiser to put on.
drifter_for_life06
Car: Daily: '16 WRX
Toys: '92 RPS13 400whp
Exocet
all yo gotta do is add maybe 6 or 7 washers on there and your done. you might need longer bolts but thats it. i did it on a 91 Celica and on a 240
burnin240sx
what does the web adress on your window say?
drifter_for_life06
Car: Daily: '16 WRX
Exocet
drifter_for_life06
Car: Daily: '16 WRX
Exocet
Nathan
I used longer bolts, and 8 washers on the back bolts, 6 on the fronts. It's perfect, doesn't rub when opening yet creates a bit of an air gap across the back. I cant tell if it really helps cooling, but I am MAD TYTE yo.l
drifter_for_life06
Car: Daily: '16 WRX
Exocet
do you need to rasei teh front also on the 240?
d12agonxboi
this might sound like a n00b but
what is the point of this mod?? :help
