jroo wrote:Brake light went out in my 04 Path. I went to change bulb and cant pull the tail light housing out. I took the two bolts on the inside of the tail light out and pulled on the housing but could never get it to pull out. I also didnt want to break the housing or a clip. What else needs to be done to get my tail light out?
get those bolts out and on the other end stick a flat head screwdriver wrapped with a cloth and "pry" it out as you pull on the bolted end side. bascially on the side thats not bolted, its like a (pardon the way i describe but its kinda the only way i can think of right now) a d!ck in a vag, no lie.... lol itll come out
fyi when you get a lil space between the car body you just pull or just keep using the screw driver (push towards the front of car)
