adidas2go »
https://forums.nicoclub.com/adidas2go-u78832.html
Tue May 13, 2008 6:49 pm
Pry out air vents using a small screw driver, pull off lower cover below radio with hands, remove the screws in all 4 corners of the radio attached to the frame. Pretty much it, from there you have to take the brackets off that hold the radio and AC together if you want to separate them
