How to pull codes from an E5 blacktop ecu...anyone know?
shawn_240sx
Car: s13 240sx
I have an E5 ecu...blacktop on an s13. No light but there is a plastic screw and the instructions are in Japanese...has anyone figured out how to pull codes from these?...I've searched and alot of specualtion with dead end threads...no one has come up with a definitive answer to this.
Sabot
I want to know too...
schanne
Car: 93 Hatch-Sr20
These instructions are for a J4 ecu, all you need to do is cross reference the pinout for your E5 ecu with the same wires. Should do the same thing. Here's a pinout chart and instructions for pulling codes.
Pin 24 on your ECU is the malfunction lamp output (LED). Wire a light between this pin and +12V. Pin 23 will act as your "screw". Tapping that to +12V for 2 seconds is the equivalent of turning the screw clockwise. So, turn the ignition to "ON", wire up the light (should be on), tap pin 23 to +12V for 2 seconds and release. The codes should come blinking out.
The way it is supposed to work (the way Nissan intended it) is pin 24 should connect to the red wire on F1, which goes to the check engine light on the S13. Pin 23 should connect to the green/red on F1 that goes to the Consult connector (for S13, only 91-94). The consult port provides +12V in the adjacent space on the Consult connector for you to short. Then you'd read codes flashing out on the check engine light.
shawn_240sx
Car: s13 240sx
Nice. Your a lifesaver bro.
RPS13 DRIFTER
Car: S13 Hatch SR'D
has anybody tested this idea to make sure it works for sure?
Mr Lee5353
Car: 89 hatch
06.5 scion xb
72 datsun 510 wagon
yeah i think i just fried my f***ing ecu following those directions. yep. i did. awesome. does anyone know how to check the codes not all janky?
Modified by leedrift at 6:12 PM 5/12/2009
Hijacker
Car: '92 240sx Convertible
'94 F-150
Odd that my E5 has a light...
Mr Lee5353
Car: 89 hatch
06.5 scion xb
72 datsun 510 wagon
Hijacker wrote:Odd that my E5 has a light...
god i wish mine did. ive got a piggy so i dont have the consult port. i dont know of any other way than this thread to check them. ive found the one where you hook it up to the check engine light and ive got a dual cam cluster, but i cant jump the two pins like your supposed to.
Steady_One_S13
Car: 1991 SR'd 240sx S13, 1993 Toyota SW21 Mr2...
leedrift wrote:yeah i think i just fried my f***ing ecu following those directions. yep. i did. awesome. does anyone know how to check the codes not all janky?
You could try doing what I did to my 91 240 w/ N62 sr2o ECU.
zerothread?id=415914
Works for the 63, E5 and E6 sr20 ECUs. Assuming that your 240is 91-94, of course.
Mr Lee5353
Car: 89 hatch
06.5 scion xb
72 datsun 510 wagon
this is the exact thread i mentioned above haha. ive got an 89.
Steady_One_S13
Oh...What you can do is wire an LED and pin to empty slot pin 24 (sr20 ecu harness) and I believe the other end to 12v. Pin 23 acts as the screw. Tapping that to +12v for 2 sec is the same as turning the screw, clockwise.
Mr Lee5353
Car: 89 hatch
06.5 scion xb
72 datsun 510 wagon
yeah thats what i tried to do- end result, some funky smell that happened to be my ecu melting. good times, just got it running right 3 days ago too.
CaEric
Car: 91 Sr Pwred Coupe
it works cause iam using a j4 on my s13 black top and i had to do this..i wireind in a lil led light to blink the code out....
Mr Lee5353
Car: 89 hatch
06.5 scion xb
72 datsun 510 wagon
yeah ik what i did wrong. i put ground to the +12v line because im a big dumbass. maybe next week when i finally get my new ecu (if i can even find one) ill be sure not to do that again.
240life
Car: 1993 Nissan 240SX S13 Coupe SR20DET blacktop
Mine don't, Jeff (heavythrottle) Told me that very few (older E5) had the light and newer motorsets came with the no light cause it was wired to flash in the dash in the 180's
Mr Lee5353
Car: 89 hatch
06.5 scion xb
72 datsun 510 wagon
wish i could find one with a light. better yet i wish i could find one in general.
