180fan »
https://forums.nicoclub.com/180fan-u3602.html
Thu Jun 17, 2004 10:44 pm
get a few meshes in different sizes. Put the large one up at the front most, middle size in the middle, smallest size closest to the intercooler. If there's a big enough a rock, it'll hit the front mesh, hopefully collapse into smaller pieces, and stop at the next mesh, but if it doesn't, then it'll probably stop at the next size mesh, or if that doesn't do it, the intercooler probably won't have much trouble deflecting it. There's a two piece design although solid pieces that are used in aerospace design all the time. Figure it'd work in this case and the probability of a piece flying through each and every mesh without hitting something and having enough energy to cause significant damage to the IC is very slim. Put about at least a cm of space between the layers. It gives the particle time to break apart.
