Shift_Altima wrote:
Can you dry with microfiber?
You can get microfiber products for any step in the process, applicator pads, wash mitt, drying towel, towels for the windows, it's all available, I'd recommend at least the microfiber cloths to remove the wax as that seems to be where you're having the most trouble.
If you're seeing streaks after removing the wax it could be:
1. The wax baked in the sun: try washing it with liquid dish soap and reapplying wax in the shade or at the beginning/end of the day, or do one panel at a time and remove the wax.
2. The cloth you used either isn't picking up enough wax or has too much wax on it: Microfiber would help this, barring that, use more CLEAN terry cloth rags (or cotton baby blankets) change them out often as you remove the wax.
3. You're using too much wax: Try and limit it to about a dime sized amount per body panel, it should be a BARELY noticeable haze when the wax dries.
4. The car wasn't clean enough after the wash: the wax will lock in anything left over from washing the car (water spots etc) be sure to use a car soap, (unless intentionally trying to strip the wax with dish soap, this should only be done once a year or for good reason..) and dry promptly after washing, not allowing the car to bake in the sun or air dry.
If there's still imperfections in the clear coat you can't get out from a wash or with dish soap:
You might want to look into a clay bar system, this will completely remove any contaminants from the clear coat, giving you a "fresh start" you can get clay bar kits at any auto store, the idea is that you use a knead-able chunk of clay with a spray wax or some type of lubricant on the clear coat. You rub the clay bar on the clear coat after spraying it with the wax and the clay then picks up anything in the clear coat because it's tacky.
That may not be the best description, but all you're looking for is a bar of clay and a spray wax if you don't have some at home already. Then spray the paint, rub the bar, repeat for entire car.
Hope that helps...
