I've seen a few posts on how to bed your new brakes. Some are different. So I figured I'd post this pic of the sheet that Brakemotive sent me on "how to bed your brakes":
Wow! The break in process sounds about right. The drilled or slotted rotors are nice. But they really don't do much except reduce weight. It's the total swept area that counts most. Drilled or slotted looks good but does not add much to overall braking. They don't even effect the cooling down process by much more than a tad. Oh well, to each his own.axefire wrote:I just installed brakemotive (powerstop) drilled-slotted rotors and their pads. So far after about 300 miles I'm VERY happy!
merlinq2 wrote:Drilled and slotted rotors are not designed to dissipate heat, they are designed to dissipate gases and reduce gas pressure between the rotor an the pad. Heat is what stops the car. The holes provide places for the gases to escape which allows for better pedal feel and less brake fade. Unless you are racing the car and need to brake late to make a turn etc, the average driver will never get the full benefit the drilled and/or slotted rotor. The drilled rotor must do something, other than reduce weight. If drilling the rotor provided no benefit then no one would set up tooling and dyes to drill the rotor. The GTR has drilled rotors- they must provide some advantage?
I also had a set of drilled and slotted rotors, I bedded them in properly and frequently, they did out last the OEM iron that was on the car.
I currently have the Brembo rotors all the way around. They weigh more than OEM, they are thicker and made of higher quality steel - 15,000 KM's and they look new, no grooving etc.
The brake motive kits are great value and will give the serviceability that you need. I went to Brembo because I got a deal on them from a co worker, if I did not get the deal I would have placed another order- will buy the brake motive kit when I am ready to replace these.
Yes my mechanic broke them in and no he did not drive the sh*t out of my car nor did he drive 200-500 miles, he did just the first steps.myother45isalesbaer wrote:Wow! The break in process sounds about right. The drilled or slotted rotors are nice. But they really don't do much except reduce weight. It's the total swept area that counts most. Drilled or slotted looks good but does not add much to overall braking. They don't even effect the cooling down process by much more than a tad. Oh well, to each his own.axefire wrote:I just installed brakemotive (powerstop) drilled-slotted rotors and their pads. So far after about 300 miles I'm VERY happy!
But I have to add to my fellow poster, you let your mechanic break them in? That is very odd. I would never let a mechanic run my car for that many miles just to break in some new pads. What's up with that? Just don't get those rotors hot and hit a puddle, they will warp and all your efforts to improve braking will be lost and you will be replacing rotors. In my OP.
Very cool. Thanks for the info...merlinq2 wrote:Yep, my dad taught me that and I have done it ever since I own cars, it takes like 10 min and from my experience has managed to reduce the amount of wrapped rotors that I have had to deal with. In Canada there are two seasons, winter and summer, twice a year is best for me.
The rotors do not warp that much what happens is that the pads deposit material on to the rotors and cause high spots. These high spots give you the juttering feel in the pedal. So the surface is no longer flat. This gives you the sensation of warping. If you every watch some one resurface(turn a rotor) you will see that they machineing process takes off very little material. It is really just cleaning the surface.
Alot of direct heat is needed to warp heavy steel, low quality pads and lots of panic stopping will result in material build up - warping.
I am not an expert but I have had many years of driving and servicing my own cars. In the old days my dad would pull the rotors and take a disc sander and clean off the rotors down to high polish - and that would extend the rotor and pad life.
So for me, the re-bedding is like polishing the rotor and cleaning the crap off.
I am not an expert.............this just works for me
I am not an expert on many things. But I did not intend to slam anyone's OP. My OP is what I posted. If you want to disagree with them, then we can have a nice discussion. If I offended you I apologize. Just give me a good reason why I am wrong. I have worked on cars for over 40 years. Maybe I am wrong, but tell me why!merlinq2 wrote:Nothing like an expert in all things related to cars to de-bunk an opinion! Wasted enough time responding.
myother45isalesbaer wrote:axefire,
We have talked before. I know where you live. I grew up in NJ and had some good friends in Long Valley I visited often. Worked at AMBEST for about 5 years. Built a house in Kingwood. I agree with much you say. Route 78 can be one nasty drive during rush hour. You can be doing high speeds and then have to slam on your brakes for some reason unknown because of traffic ahead.
I don't think the original poster did a bad thing with the way he did his rotors and pads. He actually did a good thing. What your Dad said is more than likely true. Today they build the rotors so cheaply there is not enough material left in the rotors to have them turned. They just become junk. As for drilled and slotted rotors releasing gases, that's bunk!
I am getting sick and tired of trying to have my rotors turned and still staying within State spec's. The next time I warp one, I would like to know a high quality rotor to replace it with instead of buying OEM rotors. Every SEASON? Does the other poster know we have 4 seasons? That's bunk too. I have working on cars since I was 13YO. Disk brakes did not even exist. I think the original poster did a good job in my OP. Bottom line, bedding brakes takes about 100 miles driving normally as you do. There is no special trick to the process.
Best of luck to you.
wingFeather wrote:I can't say that I've ever "bedded" brake pads. What am I missing?
Good deal on the upgrade package, though! At that price, this has to be one of the best modification values for our M's. Thanks for sharing.
