How to - Projector Fogs
PHENOMenalVinyl
Car: 08 altima coupe 2.5 mt
Ok well as some of you know i purchased a set of projector fogs without knowing that they fit. Well they do so heres my how to on it since you DO need to modify the fog light area to do so. But it is really easy you'll just go through probably 2 box cutter blades lol.
This is a daring thing to do after you do this these will be the ONLY fogs you will EVER have....unless u can find some the smae size
OK
things you need- box cutter "multiple Blades....youll see why"- The Fogs- Wiring "I already had my last fogs wired so i used the existing plugs"
1. Buy them off ebay - type in "altima projector foglights" literally just like that or you won't get the right ones. http://search.ebay.com/search/...gory0=
I paid 75 shipped and they took about a week to get there
2. They will not fit without cutting
You need to cut the inside layers out.......meaning the highlighted red part......especially the top and bottom or it wont fit
3. Next you will have to cut the little top part of the fog....cut it to where i drew the red line"ish"
after
4. Wire the Fogs and plug them in "i already had them wired"
To put them in you need to have them tilted a little so that they will go in.....dont be afraid to push them hard. They will POP in and then you can turn them so they are straight.
5. DONE turn on and enjoy
Oh and this is what happens when you dont take your time and have patience......small pieces is the key
.............do i get a cutom title now???
Coupeguy23
Car: 2006 G35 coupe sport
PhEnoM78 wrote:Ok well as some of you know i purchased a set of projector fogs without knowing that they fit. Well they do so heres my how to on it since you DO need to modify the fog light area to do so. But it is really easy you'll just go through probably 2 box cutter blades lol.
OK
after
thats a nice writeup i got OEM foglights. im going to try install my h.i.d kit tomorrow. did you have OEM foglight before these????
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
Phenom... Im not sure if this is writeup worthy lol... but ill see.. If the foglights last then its worthy, but Ebay lights usually arent the most reliable, especially if it says its a direct fit and its not.
A good idea would have been to have a dremel instead of using a razor, it would have done the work for you and made a nice clean cut.
PHENOMenalVinyl
LongBeachCoupe wrote:Phenom... Im not sure if this is writeup worthy lol... but ill see.. If the foglights last then its worthy, but Ebay lights usually arent the most reliable, especially if it says its a direct fit and its not.
idk a couple people wanted to know if they work so....i wrote it anyway lol doesnt matter..............well they are supposed to be a direct fit for an 04-06 altima
a dremel would have been better but i didnt want to do that bc i have a setup behid it and didnt want to cut that
and no i had aftermarkets before this too
bina12834
Car: 06 G35 coupe
lets get some pics of the light output and cutoff line
PHENOMenalVinyl
bina12834 wrote:lets get some pics of the light output and cutoff line
the light output from the halos is minimal....more for just looks. But the fogs themselves havent been wired yet bc i need a seperate switch
bina12834
Car: 06 G35 coupe
oh i thought you had it all wired.
PHENOMenalVinyl
bina12834 wrote:oh i thought you had it all wired.
nope just the haols....i dont have the time b4 HIN
karu11
Car: '08 Altima Coupe 3.5SE Black
where did you wire the halos to? the parking lights or fogs? or you going to have it so both the fogs and halos are turned on via fog light switch?
oh man, they look great but i fear cutting and losing the ability to use oem fogs just in case. do the fogs use the h11 plugs so its plug and play and the halos require wire splicing? (sorry if the questions are too noobish, still learning hehe)
coderedk
nice job on the writeup.. CUSTOM TITLE!!!!!!!!
PHENOMenalVinyl
coderedk wrote:nice job on the writeup.. CUSTOM TITLE!!!!!!!!
Brian said its to guetto of a writeup he doesnt love me anymore......i just wanna be special like everyone else lol
karu11 wrote:where did you wire the halos to? the parking lights or fogs? or you going to have it so both the fogs and halos are turned on via fog light switch?
um idk lol click the link to look at the plugs i dont know what plug and play is but if that wrks i wanna get them for my fogs lol......all i know is that u will need 2 seperate switches for each........i have them set up to my audi lights so wen i wanna make my car sexy flip on it goes lol my interior leds are gonna be on the same wire
DaCoupe
Car: 2009 Nissan Altima Coupe 6MT, 2006 Ninja ZX-6 636, 2011 Mustang GT 5.0
i still havent gotten my custom title for my write up and someone forgot to sticky it
but good job on the custom fogs
dudestfuplease
Car: 2009 White Altima Coupe 2.5
hey does this install not require taking the bumper off or taking off the front wheels? And also how hard is the wiring? Cause when it comes to all that stuff im a noob.=/
bunda4th
Car: 2008 Nissan Altima Coupe 2.5S 6MT
I think you got the wrong projector fog. I have Projector fog with halo and I didn't have to cut my bumper up at all. It was a direct fit for the 08-09.
Mattv609
Car: 2009 Nissan Altima Coupe 3.5 SE V6 Azure Blue
i didnt get a custom title for my subox write-up either.... so dont be sad... lol
PhEnoM78 wrote:Brian said its to guetto of a writeup he doesnt love me anymore......i just wanna be special like everyone else lol
KilaDragN
Car: 08 Altima Coupe 2.5 MT
bunda4th wrote:I think you got the wrong projector fog. I have Projector fog with halo and I didn't have to cut my bumper up at all. It was a direct fit for the 08-09.
yea.....i think he got the wrong one also.... just type in "altima COUPE projector foglights" and you should have the right ones.... hope that helps
PHENOMenalVinyl
dudestfuplease wrote:hey does this install not require taking the bumper off or taking off the front wheels? And also how hard is the wiring? Cause when it comes to all that stuff im a noob.=/
theres new ones that fit perfect
the wirings easy i went around through the door instead of doin the firewall
wen i got these they didnt make em for our car
