How to program a key fob for my 06 Sentra
spamman
Car: 06 Sentra SER Spec V
I picked up a used key fob for my 06 sentra spec-v. Can someone explain how to program it to my car? Thanks: e3
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
To reprogram (enter new ID) key fob (keyless remote controller) follow the steps.1. Get in the car and close all doors and lock all doors,2. Insert and remove the key from the ignition key cylinder more than six times within 10 seconds. (The hazard warning lamp will then flash.) NOTE: Key should be withdrawn from ignition key cylinder completely each time. NOTE: Do not rush the insertion/removal key cycling process. The side marker/tail/license lamps and interior illumination will flash twice when this step is accurately completed.3. Insert key in ignition key cylinder and turn ignition key switch to "Accessory" position At this time, the new ID code is entered and original (previous) ID codes are erased.4. Press any button on the new remote controller once. (The hazard warning lamp will then flash)NOTE:Do not press the button more than one time in the above step. If the button is pressed more than one time, the programming procedure will not be successful. The side marker/tail/license lamps and interior illumination will flash twice when this step is accurately completed and programming is successful. 6. Remove key from ignition7. Unlock driver side door, open driver side door and then close the door. (END)
spamman
Awesome advice. Worked like a charm. Odd sequencing BUT it works. Thanks!
E3
