How to prevent tire gel overspray?
Finite35
Car: 2006 Infiniti G35 Coupe
Hey guys I'm a little frustrated with overspray from tire gel. After I wash the car and apply some tire gel (the stuff you apply with a thin sponge, not the spray), and I go for a drive right away there are black spots on the side of the car from the gel flying off the spinning tire and spraying the entire side of the car.
This really sucks when I wanna drive to do a photoshoot and end up with a dirty car.
Anyone have a remedy for this?
awdjdmtalon
Car: 04 G35 Coupe, Diamond Grafite Metalic, Aero package, 6MT
Have you tryed to wipe off the excess, and let it dry b/f driving? Just a thought. Also Black Majic makes a satin finish tire dressing, that isn't wet shinny, and it drys in a few min. That is what I use, and it does not sling off, like the problem you are having.
Finite35
I've tried wiping off the excess but I guess I didn't do a good enough job. I like the wet look so I wanna stick with that. I'll have do a better job getting that stuff out of the tread grooves I guess.
Junior G
Car: 04" G35 Coupe
Apply it yourself using a high end gel and apply then wipe off excess right away then let sit for 30-60 minutes before driving to let cure on tires.problem solved
suby01
Car: 2007 Infiniti G35x
i put mine on overnight then drive it in the am whatever. never drive right after applying it, if i want to doa touch up i put the tire foam spray, in between and the gel at night .
joe603
Car: 2014 Durango R/T
Don't use gel! I use armor all wipes...no spray even when wet!
ACoupe
I use this stuff, comes with an applicator and works great!http://www.canadiantire.ca/AST...t.jsp
