How to prevent "BACK FIRING"?
NisanS13turbo
Car: Diamond White 91 Nissan Coupe
My car backfires sometimes on first and second gear and usaully happens when i shift to the next gear. What could be the problem and what can i do? Thanks guys
boost_creep
Car: 92 sr powered coupe,06 Spec V
im guessing u have ur bov vented to the atmosphere,in that case u can ricirculate it back into the intake.or just learn to deal with it.
240sxhoe
Car: chicks. gym. beer. er.... 240sx?
NisanS13turbo wrote:My car backfires sometimes on first and second gear and usaully happens when i shift to the next gear. What could be the problem and what can i do? Thanks guys
ur running rich between shifts. like he said, recirc ur bov. or get safc.
Jesse SR20
Car: 1990 S13 fastback
Like they said.
1. Re-cerc your BOV.2. Tune your fuel curve. (so you're not running rich)also3. Run a cat. Strait pipes will allow flame outs (back fires).4. Don't run too cold of a spark plug. (contributes to excess fuel out the exhaust).
NisanS13turbo
Recirculating means reroute another vacuum line back into the intake? Is this correct? Please correct me please.....thanks
boost_creep
well,yes.its actually a 1 inch i.d. hose(i think)that goes back to the intake,after the maf.
Nicksemianiw
Car: JDM 89 Silvia K's
People need to understand if your going to be runing High hp levels, high boost, 3 inch exhaust your GOING to get back fire, yes you can compinsate by puting a cat on tuning your fuel to make it leaner, but your STILL going to have backfiring!!! It wont be as bad,but it will still be there so your just going to have to learn to deal with it.
own3d
Car: 95 FD3S
I kinda like the sound of backfiring on my friends sr. but nick is right just about any car with a free flowing exhaust is going to backfire
Got13oost
Car: Kouki S13
Yes, tru that, i have back fire because i have a staight pipe, and it sounds hot~!!! and how can u tell if you are running to rich or too lean???
own3d
Car: 95 FD3S
a wideband o2 with an a/f ratio gauge, EGT gauge, sparkplugs are all good ways to tell. sparkplugs are obviously the cheap way, just pull them and generally white means lean and black means rich. the wideband o2 and a/f would be most expensive but pretty accurate. the EGT you just go by how hot or cold it is. when you start leaning out the temp will rise when your running rich itll be cooler.
Got13oost
Car: Kouki S13
icic... I need a a/f gauge then~!! another item on my list.
Nicksemianiw
Another quick way to tell is the car will run roughly and not idle very well. And leaner it will run more smooth and idel very well. Why do you think those big block musle cars sound the way they do and idel the way they do, its because they are running pig rich!
Got13oost
Car: Kouki S13
whats a good idle?? at what number RPM??
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
700-800 rpm
I have a catalitic converter and I've been dyno tuned twice, I still get backfiring.
ETTInnov04
Car: 1989 Nissan 240sx fastback
**Also, if your going to buy the A/F gauge be aware that it is almost pointless without the wideband kit. It is otherwise known as a disco light.
own3d
Car: 95 FD3S
yes, which is why id reccommend an egt gauge over an a/f. unless you plan on doing alot of tuning then you really shouldnt spend $400 or so just to see if your running rich or lean.
ETTInnov04
Yea i second the egt over the a/f. I screwed up and bought my gauges before the swap...before I knew what I really needed. So I still need my egt gauge
Onizuka
A wideband O2 sensor with a a/f gauge is much more definitive than a EGT gauge (at a larger price). Some people use both for tuning.
TougeTune180
Car: 1991 Nissan RPS13
the backfiring doesnt hurt anything though, correct? cause i kinda like it, plus when i get my new exhaust it will prolly shoot flames, which i think is pretty bad a$$. as long as it doesnt do any damage to the engine....
Nicksemianiw
Other then melting your back bumper over time it wont do anything harmfull. And if your running a cat then you will probaly have to replace that sooner then you would noremaly have to.
Calum Day
Car: '92 Nissan 240sx
Im running my sr with a cat and I still get backfires, then again Im also running rich idle around 900
nismostate
Car: all sorts of motorsports
revent the bov and you should aight. ecu is dumping more fuel because the air after being blown off is suppose to go back into the intake. when it's vented out to the atmosphere, there's not enough air to compensate the fuel being dumped into the motor.
creophus
Car: 240SX SE & 200SX
I got this same problem/issue.
