How to: Plug a tire
PapaSmurf2k3
Site Admin
Time required: About 20 minutes
Material cost: ~$10
Difficulty: 2 (very simple to do, you just might need some body strength)
Tools needed: Pliers, cutters of some sort (diagonal, scissors, etc), tire plug kit
So you likely discovered you had a flat tire at a very inopportune time. You hit the closest gas station, fill it up with air to get where you need to go, but don't want to drop it off at some shady tire shop and have them d!ck around with your car and tell you you need 4 new tires, among other things. What do you do? Plug that mother yourself.
Inspect the visible area of the bad tire. If you're lucky (which you probably aren't, because after all... you just got a fuggin flat tire) the foreign object will be visible and you won't even have to jack the car up. In the above picture I sprayed some soapy water on a suspect object to check for a slow leak, but it turned out it wasn't the culprit... so up goes the wheel/tire.
Chock a wheel that will be staying on the ground and lift the suspect wheel. Take the E-brake off or put the vehicle in neutral in order to spin the wheel around until you can find the object.
'yarrrr.... thar she blows. Get it in a good location and put the E-brake back on or put the vehicle in park/gear so it doesn't rotate around on you while you man-handle it.
Get a trusty set of pliers out and pull the culprit out of your tire. Discard it, burn it, piss on the ashes, but make sure you don't just drop it on the floor and run it back over after you've finished the repair.
Bust out the repair kit. It should have a T-handle dagger type looking thing that is rough around the shank. You're going to have to shove this into the hole that was created when the nail/object went into your tire. Depending on the size of whatever was in your tire, this could be difficult and require some upper body strength. If you had a really small hole (like from a finish nail or something), you might want to drill it out slightly bigger before trying to plunge this thing in there.
Once its in, work it around a bit to enlarge the hole and clean the inner surface.
Pull it out and locate the other T-hande that came in your kit. It sort of looks like a sewing needle, except the eye has a slot in it. Insert a plug from the kit into the eye of the "needle". Make sure the plug is rotated correctly so it goes in without too much difficulty (and will come out without too much difficulty).
Coat the plug in the rubber cement compound that came with the kit.
Next, plunge that mofo into your tire so about 2/3's of the plug is inserted into the hole. DO NOT rotate the handle.
Pull the T-handle backwards again without rotating. The plug should slip through the slit in the "needle" and stay in the tire.
Clean off the plug inserter tool so you can use it again in the future.
Now you'll notice there's some plug sticking out from the surface of your tire. Trim that back as far as possible with a pair of cutters.
Mine was in a pretty crappy spot (inside the groove), so I couldn't get to ALL of it.
Are you done? Yeah, pretty much, but Hubris hath slain many a Greek hero, so before you let the car down and call it a day, put some air in the tire (we'll say 30 psi) and spray the area with soapy water to check for air leaks. It might bubble up when you first spray it, but as long as those bubbles don't increase in size, you're ok.
That's it! Let the car down and inflate to your manufacturer's recommended pressure (usually printed on the inside of your door jamb). Don't know what it is? 32 PSI is a pretty safe bet.
bigbadberry3
Interesting. Wonder how long it would hold for and if it could possibly shoot out like a bullet. McGyver!
PapaSmurf2k3
Site Admin
I've had other plugs last the entire life of the tires. In fact, I've NEVER had one come out on me.
Mr1der
me either.
I've been plugging tires before I could legally drive.
Razi
Car: Moo
I had to do this to my tire a long time ago.
Thousands of miles later, it's still good.
alms24sebring
'04 Nissan Sentra SER SpecV
I hate the ones that you have to take off the tire for. Its soo much extra work and time and its never as effective. There is absolutely nothing wrong with this kind of plug and it usually lasts the rest of the life of the tire 95% of the time.
300ZXttZMAN
PapaSmurf2k3 wrote:I've had other plugs last the entire life of the tires. In fact, I've NEVER had one come out on me.
Me too even on my 35" Nitto Mud grapplers on my daily I have like 2 plugs just on 1 tire and they have been holding since I was 16. I am 20 now. Good article Papasmurf.
szh
Car: 2018 Tesla Model 3.
Simple fix :yesnod
But please do remember that adding plugs (and even internal patches) to a tire automatically reduce the speed rating of the tire.
So, you should never go for very high-speed drives with any tire on the car that has been repaired in any way ... never exceed 100mph in a car with such a tire. :biggrin:
Z
93coupe
Car: crap
All the tire plug kit's I've used have had directions and illustrations on the packaging.
ricebike
2002 Quest
2005 Altima
alms24sebring wrote:I hate the ones that you have to take off the tire for. Its soo much extra work and time and its never as effective. There is absolutely nothing wrong with this kind of plug and it usually lasts the rest of the life of the tire 95% of the time.
as a NICO-dad now, I rather have the tire removed, patched from the inside, remounted on the rim- rebalanced the whole assembly... just for the safety of not having it fail in the future...
i've had 2 that fail later on using tire plugs before. they do damage those steel belts when your rasping that hole in prep for the plug.
If these are cheapo drorifto tires, or if your tire is close to the end of their useful life then yes, this will be a temp band-aid.
I have purchased tires with the road-hazard /free repairs for flats that are inclusive so I don't need to resort to this anymore :whistle:
PapaSmurf2k3
Site Admin
Jesus man, where were you getting it done at? You seem to be the only one in this thread that has ever had one fail on you, and you've had 2!
These tires are on my daily driver and have been on the vehicle for about a year. There is TONS of tread life left on them.
alms24sebring
I agree. Ive only seen very few fail and most of those were double pugs or more of a slash that a hole. I think the internal patch is less safe to be honest. It doesnt fit in and stick as well and alot of times the patch has a hard time staying glued down.
ricebike
2002 Quest
2005 Altima
mind you i was doing your method since 1993 & have plugged many a tire this way when I was single & was piss poor to afford new tires (i was getting them used back in the day because my main transport was a motorcycle 3 seasons out of the year).
alms24sebring wrote: ...it (tire plug repair) usually lasts the rest of the life of the tire 95% of the time.
so this rings true out of the ~50+ plug repairs i've done on my vehicle as well as friends/ family's vehicles. i had one of them on the old photo album of this site (can't find it now. or was it archived in some dead space that i am not aware of?)
as soon as y2k came around, got hitched, started forming mini-MEs, I opted for the latter patch type repairs instead, just for safety.
i did see a tire/plug combo once, but haven't seen that lately
are these being used currently? can a tire tech/ dealer tech answer this? thanx :gotme
Philipio
Car: 96 240sx, 96 Miata
szh wrote:Simple fix :yesnod
Z
I had to get a tire plugged the day after I bought my Miata. I ended up hitting 100mph without realizing it a couple weeks later and was very, very thankful nothing happened when I realized how fast I was going. The plug ended up lasting the life of the tire.
alms24sebring
Yes that is the type of tire plug I was referring to, those are the plugs that you must take the tire off for and plug from the inside. Not sure if dealers use them or not. Ive only had to use them at one place I have worked and they suck! I hate them and they are such a waste of time and effort.
