How To Pick A Factory Remote
zach7685
Car: 2002 Infiniti QX4
2001.5 Nissan Pathfinder SE
2003-Subaru Baja
1989 Nissan Maxima
2003 GMC Savanna
2002 Mini Cooper S
1968 Mercedes 230-Sold
2005 VW beetle Convertible
2001.1 Nissan Pathfinder LE
This is to clear up any confusion about the two model remotes.
zach7685
2003-Subaru Baja
1989 Nissan Maxima
2003 GMC Savanna
2002 Mini Cooper S
zach7685
2003-Subaru Baja
1989 Nissan Maxima
2003 GMC Savanna
2002 Mini Cooper S
Sorry for it looking so big and stuff i cant for the life of me figure out how to post flicker photos.
ltsnotme
Car: 1996 Pathfinder XE 4WD
Where's picture 2
zach7685
2003-Subaru Baja
1989 Nissan Maxima
2003 GMC Savanna
2002 Mini Cooper S
Sorry Here you go! :) i also have all the other numbers but don't want to post them in the pathfinder forum
ltsnotme
yep, that looks like mine.
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
Excellent info, thanks!
zach7685
2003-Subaru Baja
1989 Nissan Maxima
2003 GMC Savanna
2002 Mini Cooper S
PM me for the others if you need them.
zach7685
2003-Subaru Baja
1989 Nissan Maxima
2003 GMC Savanna
2002 Mini Cooper S
QX4 remotes and pathfinder remotes are interchangeable along as the models # match.
zach7685
2003-Subaru Baja
1989 Nissan Maxima
2003 GMC Savanna
2002 Mini Cooper S
Made an interesting discovery today went out to my parts bucked and found a remote i pulled from a Infiniti G20 at a junkyard. I was planning on buying one but it didn't have the remote.
I got it to work in my pathfinder! :woot: Going to put it in a hide a key box and mount it. The trunk button do-sent do any thing and its a / model. it seems their are more possibility than just the Direct Replacement models!
zach7685
2003-Subaru Baja
1989 Nissan Maxima
2003 GMC Savanna
2002 Mini Cooper S
Towncivilian
Great, thanks! I've merged all your posts into one.
I have a 2001.5 (10/00 build date) and I have two Model / A remotes, as the chart explains.
Towncivilian
Some of the images died, can you fix them?
zach7685
2003-Subaru Baja
1989 Nissan Maxima
2003 GMC Savanna
2002 Mini Cooper S
Why does this happen?
Towncivilian
Photobucket's been on the fritz lately, they revised their site and it's been crappy for me too. I've switched to imgur.
Thanks for fixing the images so quickly.
barkingdog
Car: 2001 Pathfinder
I have a manufacering date of 9/00 for my pathfinder but still don't seem to know what key remote to order. I see 5W500 but I can't seem to find that number on ebay for a pathfinder. Thanks for any help.
Towncivilian
You need 28268-2W602.
r51
Car: 2007 Nissan Pathfinder Ti diesel
Hi
Have a Spanish build 2007 Pathfinder R51 (sold in Australia) with a code on the back of the remote that says 5WK4 876/818 433 MhZ
Also says Siemens VDO
Its a two button square type remote
My Xhorse says its a ASK 433.90 / 433.91 with Baud 259 and 1010 bits
what remote models might work to get a spare one
regards
mdmellott
Car: '13 Kia Soul+ 2.0L AT
r51 wrote:
Sat Nov 12, 2022 5:38 am
I don't know about Xhorse or any other aftermarket universal brands but there are OEM knockoffs and actual OEM product available. Here are a few places to look. >>>
https://www.ebay.com/itm/333836102447
https://www.ebay.com/itm/184713282960
https://www.mk3.com/nissan-qashqai-micr ... k4-876-818
https://www.reidsremotes.com.au/car-key ... nuine.html
r51
Just to add, this is not a keyless or intelligent remote, just a normal 2 button one.
The next question is can I pair this without using Nissan Consult II as it seems the only stick the key in 6 times method only works for the remote keyless entry system one (based on 2007 Service manual BL-62).
mdmellott
r51 wrote:
Sat Nov 12, 2022 6:59 pm
As long as you get the proper remote with a transponder and a key blank you can cut to match your existing key, there should be no issues registering the new remote with your Pathfinder using the manual method without Consult II.
