fatboy wrote:umm, i dont bleed each individual brake. you dont have to mos the time. bench bleed the master cylinder before putting it in the car. (bench bleeding is purging air from the actual master cylinder before putting it in or at least purging the majority of the air). make sure the fluid level is good. bolt it back up, put lines back on. get someone to pump it up, crack master cylinder lines open one at a time like you're bleeding a caliper. do teh same until theres no more air coming out of the lines. check for pedal feel. you're good to go.
FatBoy has a huge point right here.
Bench bleeding is a must if you are swapping in new mastercylinders. If you just throw it on the car and fill it with fluid "and let it sit until fluid starts to drip" you are going to be SOL when you need the brakes.
There are air pockets that form in the mastercylinder when simply pouring fluid into it. The best way to remove these is to attach the reservoir to the new M/C fill it with fluid, and with a towel(use it to protect the piston from the head of the screwdriver) and a screw driver(preferably phillips head) push the M/C piston in until it bottoms out. Watch the reservoir, as bubbles should appear in the fluid. I would also attach rubber hosing to the brake ports and set them down in some brake fluid as well this will also have bubbles appear in it. Repeat until all bubbles are gone and add fluid to the reservoir as needed.
The brake department is something you don't want to mess around with. If you don't know what you are doing, take the M/C to a auto shop tell them what you are doing and ask them to bench bleed the M/C for you, if you don't feel comfortable doing it yourself.
Glenn
